I stand corected
I only use range or tempest or gledhill cylinders
Never used megaflow my suppliers dint stock them
If the incoming mains is of the higher pressure and flow than needed the pressure reducing valve takes it down to the correct pressure
So if the correct checks are done before a cylinder is fitted 22mm is the correct way to do it
so, if you do not get the required readings after doing your checks and you have an incoming 25mm main, you would automatically step up to 28mm?
P+V=F not P+F=V🙄
And does that make me wrong??
cool, what solar systems you installing? have you had much to do with this drain back system mate?
But what would be best to connect to?, a 1/2 inch lead supply giving 25ltrs a minute@ 3bar or a 32mm mdpe supply giving 14ltrs @ 1.5bar, its not the size that counts somtimes.
so you think that 32mm pipe supplying at 1.5bar will only give 14ltr/m , go do some maths then come back with a sensible reply.😛😛
No because you will still have 28mm volume at 1.5bar until there is enough flow taken off to cause a significant pressure drop at the inlet then it would flow as incoming , however depending on the length of 28mm installed it would need to be a significant amount to cause this , the 28 would act as a buffer/accumulater. 😉🙂
Reply to the thread, titled "Megaflow cold feed." which is posted in UK Plumbers Forums on Plumbers Forums.
