M
mikimac
Hi all,
I've just had a call from a contractor I do a lot of work for to ask if I'd change a G4 meter at a property to U16. There is a 1" barrel upstream & so I'm assuming that the mains pressure will be sufficient. As I've only put sub meters in before does anyone know what the procedure is regarding notifying the gas supplier about a change in meter & readings...is it even ok for me to do ( I have met1). Any advice would be appreciated. Thanks
