F
Foodface
Got myself in a pickle, did a safety check on a brand new Worcester combi with a vertical flue going up through a small concealed loft space. No access hatches, completed the rest of the test and AR'd it informing the letting agent that they need to put in access hatches. I turned the boiler off, warning notice and stickered it.
Landlord has had someone put to quote for access hatches costing 100's of pounds, now they are kicking off and the boiler has been switched back on as I took fuse out of spur, but has been replaced.
Is there anything else I can do? As I'm worried about any further come repercussions.
Foodface
Did you get a signature on the warning notice? If so, and they have chosen to ignore it and replace the fuse, you're OK in my opinion.
You have done what is required of you, following Industry procedure. Depending on how strongly you feel, as you may need to nurture your relationship with the landlord for further work. You could inform The HSE of the situation, as this is a hot topic for them they might take action against the landlord.
Reactions: 2 people
how deep is the roof space - if the flue passes through in one piece no joints eg boiler in corner of bungalow and vert flue passes through without a joint that's ok
he wouldnt know, there was no access:yesnod:
Reactions: 2 people
Didn't the Bee Gee's sing "How deep is your roof space?". Would have replied sooner but been a busy day (spent two hours in plumb center waiting to be served). I'm going back next week to hopefully put an access hatch by the flue terminal and then one a story up, as it goes through one story.
It's always in new builds where I come across this problem (sure there are older installs too) but I kind of feel like we have been sold up the river in the sense of I flagged one up two weeks before the regs came in to force and the customer rang gas safe as it was a 1 million pound grand designs type house. They were well miffed, apparently Gas Safe told them not to worry about it if I turn it off as I need their permission anyway (which I did when I returned in the new year) and they can just turn it on again.
Which begs the question, if you are going to turn something off or take a fuse out knowing that customers will turn it on again then why are the regs there if we have no powers to enforce them?
Personally I think it's a good idea to inspect the flues in voids as there are too many arse holes about putting in shoddy work but wish gas safe would make more information clearer for the public. Saves getting into pickles when working in new builds.
Its about coving your bum. If the responsible person for the premises ignores your warning notice, it is at their periled if it harms someone. Don't worry about it, as long as you have documented and followed the industry procedure.
