hammers4spanner
Subscribed
Mar 21, 2012
7,703
3,197
113
Long story short got asked to do a landlord cert where boiler had a fault , got messed about something chronic on repair by suppliers then the tenant. Got the boiler working and was doing the cert and again messed about by tenant.
3 weeks later boiler went down again and owner got out the manufacturers engineer ,stupidly when i done the cert i forgot to check for access hatch as flue crossed over the hallway .Thus the flue passes through a void of about 1200mm till it terminates.
Now Manu's engineer has at risked boiler and owner has left answer phone message of how come never done that .
What you guys reckon of flue in small void like that?
Even tho you can clearly inspect flue from the cupboard, would you need a hatch over the short space?
Shine a torch down yeah , however with all the aggro i never looked in the hall for hatch which the MANU engineer noted as AR by sounds of it
Well you can see the Flue over its length but as no inspection hatches its AR , i hold my hand up and missed the look for a hatch but you can see the flue length clearly from cupboard.
maybe i was wrong maybe MANU engineer gone overkill .
Either way in my next life I'm going to be a plasterer .
"Well you can see the Flue over its length" but as no inspection hatches its AR , i hold my hand up and missed the look for a hatch but you can see the flue length clearly from cupboard.
if anything comes off it say that, you should be fine flue readings fine?
Read the Flue in void TB.
It states using a common sense approach where having enough sight of flue running along the duct may alleviate the need for inspection hatches so is not automatically AR!
If I can visibly see enough to say flue is intact along its length and FGA is good it is just advice on hatches!
Well after all that turned up today and inspection hatch was in , i'm going mad asked tenant was that their before and she confirmed i looked inside it.
Turned out manufacture engineer never looked inside it as couldn't open it so issued AR !!!
Never know could have used a 2Mtr length of flue so would not be any joints to inspect anyway except for above boiler
If you can see the full length of the flue from the cupboard there is no need for inspection hatch. Inspection hatch is there to enable you to inspect the flue, if you can inspect it as it is, why should there be a need for a hatch?
I service a boiler with 8m flue installed down an old stone chimney, no way to fit hatches in. I fga incoming air and if that's ok then thats good enough for me.
there are special types for situations like that
you sure its not one of them other than 1-2m lengths
