Darren Jackson
1,021
741
113
56
Leeds
Heating Engineer (Has GSR)
Remeha Avanta+28C, I went to do a landlords and found that the front case was damaged, it had the two tabs that secure the front on to the main body broken off so no way to securely fit the front back on. As this case front should form a room seal & acts as an air box I stuck on a do not use label, turned it off and AR it. filled out the warning notice & I explained to the tenant that if it is used it could cause a danger in the future if the combustion seal becomes defective or if the inner flue corrodes the POC could get pulled back into the boiler and out of the broken case seal into the room if left like that & they happily signed the warning notice. Also the Exp vessel was leaking out of the schrieder valve onto the electrics and there were signs of corrosion on the main body case floor around the hydrolic block. the pressure gauge did not work & the PRV is letting by due to knackered EXP vessel. I suggested due to the age & condition of the boiler it would be better to replace rather than repair. 2 days later I get an email from Gas Safe saying that a complaint has been made about my work & I now have to meet a Gas Safe inspector at the job on the 19th at 1pm to go through it with him and the Landlord. So an afternoon with out pay!
Now I am second guessing myself & wondering if I was too harsh or wrongly AR'd it. What would you guys have done?
Correct loose case box / seal is ar poc coming back in id
Did you take pics ?
No foolishly I didn't but luckily the tenant did, and she willingly signed the warning notice. I have visions of returning on the 19th and a new cover has been put on it... I am sure his tenant will not be happy waiting until at least the 19th without hot water & heating until the landlord & Gas Safe decided if I was correct in AR'ing the boiler or not. Never had a complaint made against me and this has wound me up. Just doing my job and protecting people.
  • Winner
Reactions: Burger
My thoughts exactly or a repair been done then your kinda up craps river as you have no proof just there word against yours
Reactions: Burger
Surely you have a (Carbon) copy of your warning notice?
Personally if found to be backed up by gas safe, I would be billing the landlord for loss of income.
I use the official Gas Safe report pads, so they are all in triplicate & I have the copies. I thought about invoicing for the time myself & If I am backed up by Gas Safe that is exactly what I will be doing. (but I wont hold my breath for getting paid).
Reactions: Gasmk1 and Burger
good job i read your post as that was my thoughts.
Reactions: Burger
Im guessing it was the landlord who made the complaint, and not the tenant?
Yes it is the Landord who has lodged a complaint, the tenant was horrified that her children could be in danger. She said she has never had cp12 done in 3yrs she has been there!!
Reactions: Burger
If that’s the case, no wonder the landlord is kicking up a Rubbish storm.... hoping to mask the fact a safety check hasn’t been done in 3 years. I hope you kindly mention it to the inspector. You’ve done nothing wrong and shouldn’t worry.
