Desperatedan
I have a pumped gas central heating system. I recently had to replace the mv (honeywell) with a sunvic 3 port , 3 position valve (CH,WH,Mid position). I was told that this should work ok.
The problem I have is that the actuator will not respond to HW stat call when the room stat is SATISFIED - other than this the mv works fine, however it does not seem to be able to stop in mid position; the system did not do this previously.
The controls are linked through a Drayton RB2 control box.The system is time controlled ; separate instructions for HW only or Room heating are not present. Previously the system gave priority to WH over RH.
The connections to the RB2 are as follows-
Terminal 1 (A)......mv(grey), cyl stat (satisfied)
2(A)......room stat ,I think
3(B)......cyl stat (common)
4(B........live feed (2 red wires)
5(1)......pump (blue)
6(1)......mv (blue)
7(2)......cyl stat (demand)
8(3)......room stat (demand)..I think
9(4)......mv (orange)
10(5).....mv (white)
11 (6).....pump (orange)
All wire connections are as previously with only the wires from the new mv being connected in a similar arrangement as the earlier mv ie. similar colours to same terminals .
I hope that someone might be able to advise how I can correct this situation.
6(1)......mv (blue)
