View the thread, titled "Multi tools!?" which is posted in Plumbing Tools on UK Plumbers Forums.
Whn1
240v multitool. About to finally take the plunge and get one for those awkward floor boards and joists.
what ones do you recommend.
A circular saw is a much easier way of lifting floorboards but if the customer has got nice sanded boards a multimaster puts a much neater cut across the boards and as a bonus doesn't chuck sawdust everywhere.
Need to cut a metal pipe off flush with a wall. A grinder is quickest but throws sparks everywhere. A recip saw will take it off in a flash but is inclined to leave score marks in the wall. A multimaster will do a lot less damage to the surrounding surfaces.
Need to take a board out under a bath. Circular saw won't fit, recip saw will but is a bit vicious to be flailing around under a plastic bath. Turn the blade sideways in a multimaster and you have the ideal tool.
I've yet to find another tool that will cut a board right next to the skirting without damaging the skirting.
I've used mine to cut out a section of soil pipe, to insert a branch when the soil was set in a recess with no access for any other type of saw other than one of those awful hand held wire things.
There are generally other tools that you can use but they don't do the job with the same level of finesse.
Can these cut cast iron soil stack pipe or am I better off using an angle grinder?
Cheers chaps
yes i would say an angle grinder for cutting last iron. although there is a technique i haven't used whereby you cut halfway through with a hacksaw and whack it with a lump hammer and it is supposed to break cleanly where you have cut through.
A recip saw will work on a cast iron stack with the right blade. A grinder chucks iron filings everywhere and they rust and stain.
Chain saws might also be available on Friday nights.
I used to live in a village and my dad was a prosecuting solicitor (the one who gives the police side of the story to courts).
Back in the 1980's he prosecuted a couple of village blokes who were attacking each other with running, petrol chain saws. I never did hear if one or both ended up in hospital (or the local asylum).
Reminds me of when i was young and watched 2 local halfwits settle an argument with shotguns and bucket lids at 40 paces!
Both of them got hit but they were fine after they picked the pellets out :lol:
Reply to the thread, titled "Multi tools!?" which is posted in Plumbing Tools on Plumbers Forums.
Thread starter
Whn1
Joined
Location
London
Thread Information
Title
Multi tools!?
Prefix
N/A
Forum
Plumbing Tools
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
None
Whn1,
TBServices,
