rocketmanbkk
4,106
903
113
Langley, Berkshire
Dear Friends
My Mum is 80 this year and she's had low pressure to the bath taps (just told me!) for ages.
In her 1st floor airing cupboard is her tank and the cwsc directly connected.
If I was to put a pump in and connect to the bath taps would this solve the issue? She has electric in the airing cupboard.
Or is it better to put a new tank in and put a tank in the loft to give more head height?
Cheapest solution really.
Best regards
Rocket.
Thanks for the reply. She doesn't have a combi. I thought about the taps, she is not keen!!! I'll have a look for another set of mixers with shower attach as she has now.
Best regards
i did not mean a combination boiler but a combination cylinder (cylinder with tank sat on top). most mixer taps will have poor flow compared to a standard single tap. It may be cheaper to get a electric shower installed.
Sorry! Misunderstood.
The combit tank is now in the airing cupboard. Would it be tetter to change so that the tank have a CWSC in the loft to give it more pressure? Or do you mean to put the whole combi system in the attic? ( I don't think it will fit through the access hatch).
Thanks for advice on mixer taps also, wasn't aware they had less pressure as the ones put were for low pressure systems. When she had single taps, all was fine. May just change taps to pillar taps but she'll have to go back to the old fashoined rubber hose unit to wash her hair.
The easiest thing to do is as Awheating said. Just a matter of extending the pipes then and it will increase the head by a couple of meters.
If you want to put a new cwsc in the loft you will need a new cylinder too. A lot of expense for little gain. If the cylinder won't fit through the hatch cut it bigger.
No matter what shower attachment you fit it won't work if you lift it up higher than the combination cylinder. You can't pump from a combination tank either.
OK, what I think I'll do 1st is change her taps back as she was happy before.
If not good, I'll buy a new tavk and cwsc and remove old conmbi, put tank in airing and cwsc in loft.
Should be a winner, more expense but I need her happy, she's me mum!!
Thanks again for the reply.
Moving the combination tank to the loft will give you more head unless you build a tank stool. It will also work just as well.
My Dad had a similar situation, if you were standing in the bath the water height in the CWSC was around eye level. A Triton AS2000XT Thermostatic Power Shower has done a great job for a number of years.
Would this not be negligible though? The head in this case will be operating on the distance between the water level in the cwsc and the connected cylinder. Therefore being the same whether in the loft or on the roof. There may be a small advantage gained from an increased drop on the pipework but imo not worthy of the effort involved.
Sent from my GT-I9100 using Tapatalk
you've lost me with that one mate!
talking about the benefit or lack thereof of moving the combination cylinder to the loft.
if it wasn't a combination cylinder pressure could be increased by raising the cwsc as high as poss above the cylinder ie in loft. but with the combi cylinder in loft you aren't really increasing head (standing pressure) because the cylinder is being raised as well as the cwsc because they are conjoined.
sounds like the problem is reduced pressure due to a limited head of water, but scale build up in the pipes over time can cause similar issues
what he means if the you had a seperate cwsc the higher you can raise it above the cylinder the greater the pressure into the cylinder thus giving greater pressure to the taps but as its all in one you cant increase the the pressure to the cylinder no matter how high you lift it
