Guest viewing limit reached
My first cylinder install with boiler
View the thread, titled "My first cylinder install with boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi Guys,
Update for anyone that is still interested, or has the will to live!
I’ve spoke to one of the tech advisers at the CIPHE and he’s said G3 regs only cover the potable water discharges into D1 & D2, and not the discharges from central heating. Therefore you shouldn’t combine them.
I then asked him where it says in any doc or reg that you cannot do it, and he basically said if an incident happened (I.e flood from tundish causing water damage due to all discharges blowing off at same time or others etc) and it went to court then the expert witness’s would pull out the G3 discharge drawing (the one that’s in all u/v cylinder install instructions) and then basically say show me on that drawing where it shows that the central heating blow-off is allowed to be connected into the D1/D2 pipework.
As we all know the drawing shows no such thing.
Hope this helps anyone out in the future.
Cheers.
Your best person to as is building control also not totally true
Found this in the G3 regs
Thanks for that Shaun, I read that before when I was checking up and that just refers to blow-offs from domestic water and not heating, as G3 covers vented/unvented domestic water only and not central heating (or central heating blow-offs).
With building control I have to disagree with you, the CIPHE help write the regs and standards etc in conjunction with others like APHC and HHIC so if anyone knows what they’re talking about it’s them.
Just putting it out there 🙂
Wrong G3 covers anything under the umbrella of vented, unvented and solar etc( which a heating system is an unvented system just no stored water)
Also doesn't state just potable water only says discharge from safety device
Also ciphe do help but overall but building control write them and enforce them also they the regulating body
Hi Guys,
Cheers.
Well I’ll be...
I think your having trouble interpreting the regs Shaun, so you just carry on as you are. If you need clarification from people more intelligent than me and who can explain better than me then please ring CIPHE tech for assistance 😉
Tried to help by doing some proper research so I hope it can be of use to others.
Thanks again.
Hi Guys,
Cheers.
Totally hear you, but it also does not state that it cannot be connected to a CH PRV. So it’s kind of down to interpretation in my eyes. In an u/v cylinder manual I believe it will only discuss the discharge from that appliance, and not others ie central heating so the drawing will only display that of the u/v discharge pipework.
I’m the first, as others will tell you, if I’ve done something and it’s wrong I will immediately go and rectify my mistake and learn from it. But unless I read something that tells me a c/h PRV cannot be connected to the u/v discharge pipework I think I’ll continue to do as I’ve done here. However, I will do some research also and try to get a definitive answer (he says!) from somewhere.
Thanks again.
thats the thing they have nothing to do with building regs enforcement / tell if is wrong
Same as me Jay, never stop learning.
Try ringing CIPHE tech like I did, they will provide a definite answer and they deal with cases like this in court as they are expert plumbing witness’s, if you want I can post up their telephone number?
They can also explain better than I can on a keyboard 😀
Reply to the thread, titled "My first cylinder install with boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
jaydebruyne,
mikeygas,
