E
errigle
Hi guys,
I have a 6 year old Vokera Mynute 20e that has stopped working. It has had a new pcb about two years ago and been serviced a few times.
Having just come back from a weeks holiday where we had turned the time clock off, it simply won't fire. Controlled by a danfoss clock and box. Pre-payment meter installed but full of credit. I did start to check the 240v connections but my multi meter just packed up. Warning light is not flashing red (like it normally does if the gas has ran out etc) or any colour. Pressure is around 1bar. The safety valve does have a small leak which i've never got round to sorting out but i do keep the presure topped up with the filling loop.
Basically when i call for heating or hot water the fan and pump (i think) will start running but no ignition. Both motorized valves are working normally although the heating one has got stuck a few months back but no problems since.
Anybody any ideas what to check??
Thanks Philip
Hi Philip and :welcome: to the forum 🙂
Alas if you have power to the boiler and things are happening behind the case then the issue lies within! Could be something simple though and shouldn't cost you that much 🙂
