T
Tawny64
I am crrently working on the above, it has had the low and high thermostats and overheat thermost recently replaced together with the igniter, pilot jet and thermocouple. Room stat is operating as it should and the sytem pump is new. The boiler will only run for a short while, cycling between burner on and off. Flame is strong and blue with no sooting (Burner box all clean as a whistle) the house never getting up to temperature. System has been recently flushed and refilled with no air locks, rads get warm but never hot (all valves are open fully). The 3 way valve is opening and supplying heat to the HW cylinder when switched and in the auto position. I am thinking there is a main gas valve fault, yet the boiler will fire up and cycle but only for a short burn time which does not ever heat the radiators or HW up to temperature even if the roomstat is set to maximum. I am reluctant to replace the gas valve (all other work being undertaken prior to my involvement) if this indeed may not be the problem. Switching the boiler thermostat from high to low or vice versa and bypassing the overheat thermostat (new as above) make no difference. Power is not being lost at the solenoid when the burner goes out and the system pump runs continuously when the boiler is switched on. Maximum run time varies (around 15 mins burner on max) even with the house asolutely frezing and the room stat calling for heat. Any suggestions?
The Apollo 40B can be range rated 8.8 to 11.7kW.
1. Have you checked what output it is providing by gas rating it?
2. Have you checked what the total output of the rads are? (Use the first table in Stelrad Elite Catalogue or assume 1.5kw per rad.)
You need a gsr in to look at your boiler. We cannot and will not give advice on the installation or repair of boilers for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a pm to either Gas man or Redsaw who will then check you and then give you access to the gsr private forum.
Thank you.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
