K
kid apology
Hello Plumbers i need a bit of info .. i am not a plumber i am a builder and i had my plumber install a new boiler in an extension that i built three years ago ( vaillant eco tec plus 827 i think from memory ) it is approx 12 meters from meter with at least 4 90 bends and a cooker and gas hob on the run he piped it with 22mm all the way to boiler with 15mm spurs off to cooker and hob .....now heres the prob 3 years later customer has prob with boiler that has now obviosly run out of warranty but he has covered with british gas ( please stay with me 🙄) gas comes out and says that he is only getting 14 gas pressure when he should be getting 17-22 at boiler so he rings plumber through me and it goes like this cstmr " my boiler is not getting enough gas to it " my plmbr " are you f**king oking it was over three years ago not my prob " so he now refuses to go back !!! cstmr doesnt want him back !!! and stuck in the middle !!! so does the boiler need bigger pipe supply or is set up as described adequate ???? or could it be blockage ????? ps gas board checked governor and all ok at meter . any suggestions would be greatly appreciated
