No i don't. Why, is that likely to causeba problem too?Do you have a water meter?
Thanks, was looking at this currently. Was about to use a few saddle clamps on the straight run first and see if that helps.I would try putting a small expansion tank on a tee right where the water line comes in. It will act as a big shock arrestor. When you secure your pipesuse something with a rubber insert. I don't know what you have available but I would suggest short pieces of insulation with a larger pipe clip around it. This way the foam insulation acts as a vibration dampener.
If you can get some polyethylene water line you could make a loop at the main, this may help with vibration as well.
I have lifted floor and see the hot pipes are, as you indicated, also affected.Combi boiler will not help. Now all your water pipes are on mains pressure running through the boiler, so any pressure surge from the mains supply will affect your hot pipes too, to some degree.
Hi scott_d , can you, or any other posters , recomend any particular makes of shock arrestor and pressure reducing valve from experience?Shutting the stop tap reduces flow not pressure
Cut out any dead legs that can trap air
Clip pipes
Pressure reducing valve
Shock arrestor
