Looks like a Mira Element recessed thermostatic valve shower.
Temp on that can be adjusted, can be a bit fiddly but not a big job.
May bring back the temps you have been used to with previous boiler.
Hope that helps,
Andy
  • Agree
Reactions: jtsplumbing
Hot water will go up to 60, its possible that the thermostat in your shower may be on its way out, or shower temp setting may need adjusting.
Make sure you don’t have that guy back!
Oh he's coming back Dan.. Next week.. To complete a new commissioning checklist because the first had so many omissions and errors... Not even signed. Baxi suggested a new one be filled out.
I can't quite believe how I was treated... The worst was being threatened by his wife with the police being called if I "trespassed" to hand deliver the second email that was ignored.. All this after numerous texts and calls had also been ignored... I could go on. He will not set foot in my house again after completing the checklist ... Unless I am lucky enough to be accepted by Gas safe for a free check and he chooses to be there.
Seems like you have been treated badly barbara there is no excuse for not compleating the benchmark checklist , every gas appliance which needs registering with gas safe is entitled to a free gas safety check by a representative employed by gas safe all you need to do is tick the box in the paperwork that should have arrived with your gas safe certificate . as i have said before the water temperature coming out the ground this time of year is only around 10 degrees your boiler can only raise this by 35 degrees at a flow rate of 10ish litres a minute so if you turn your hot tap full on or your shower then the cold water passing through your boilers plate heat exchanger cannot be heated up enough to provide you with 55 degrees of hotwater the only way to get hotter water is to slow down the rate it passes through the boiler this is what your installer would have done at the stopcock or at the boiler , this is always a issue in winter with a combi boilers you could fit a flow restrictor (ECOSTAR PRODUCTS) to your shower head which will only allow 8 litres a minute of water to come through your shower head you will see the hotwater temperature will be better and you wont notice the slight drop in pressure as you can have a hotter shower , your baxi boiler has a 7 year manufacturers warranty and is a very good boiler and should give you years of service if you look after it and have it serviced every year . kind regards kop
Thanks for replying kop. Your reply is really helpful and makes sense.
Reactions: king of pipes
