New Boiler Being Fitted; heat only or combi boiler?
View the thread, titled "New Boiler Being Fitted; heat only or combi boiler?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Alan Wright
Subscribed
I am having a new gas boiler fitted for central heating only.
The pump needs to be part of and contained within the boiler.
What boiler do I need?
Heat only or Combinaton boiler ..... or?
Cylinder or no cylinder
This is the advice I got yesterday:-
If you want hot water for the central heating system only, you do NOT want a combination boiler. If you require the pump to be inside the boiler casing, you would use a SYSTEM BOILER which would give you a sealed system.
It would be best to get a recommendation from your gas safe engineer.
The flow and return are vented to a tank in the loft.
Does this change the advice?
Reply to the thread, titled "New Boiler Being Fitted; heat only or combi boiler?" which is posted in UK Plumbers Forums on Plumbers Forums.
Alan Wright,
Alan Wright,
