View the thread, titled "New Boiler installation" which is posted in Boiler Advice Forum on UK Plumbers Forums.
sp25
Dear all,
My boiler has given up few months ago and urgently in need of a new boiler. It'a very big decision as its a huge amount and i want to be able to install a reliable one. Having suffered with no heating/hot water i am very cautious esp as i have a little baby.
I have narrowed it down to Baxi platinum HE28 A. It was a tough choice between Baxi, Vaillant Ecotech Pro & Vaillant Ecotech Plus.
I am not sure which is the best as there seems to be lots of brands and also mixed opinions. However, I was hoping you could share your expert opinions please.
Thanks in advance.
Has any one been to survey your house ? Had any quotes ? or are you doing the job yourself, ? look at your hot water use age will the 28 give you the amount of hot water you use, not a great difference in price between the 28 & 33 Platinum, if your after a long warranty go for the Baxi, But other boilers now offering long warranty's, but it will depend if installer is on company's list of recommended engineer's, As for opinion's on witch boiler we all favour different makes, so you will get different answers, are you on Natural or LPG gas ?
Having read your other post, have you had a gsr look at your boiler, rather than an electrician?
As for new boiler, get minimum of three estimates and go from there.
Thanks Simon, Ermintrude & jtsplumbing,
Yes we had a boiler installation company who helped me do an initial gas safety testing do us a quote. As its a 2BR/1Bath property they recommended Glowworm flexicom cxi24 and Vaillant Pro24. Another company I found on an online forum also did a quote after visit and they gave me a lot of options at a reasonable price too. One of the options is a Baxi.
I spoke to both Vaillant and Baxi and found it took me 45 minutes to get to Vaillant/Glowworm and they didn't seem keen to answer my queries. Baxi on the other hand took less than 10 minutes and i called them about four times each time when i had a new query and they were amazingly helpful. This was one of the reasons in addition to the 10yr guarantee i felt swayed towards Baxi rather than Vaillant.
So jtsplumbing, do I require Platinum 33 for my flat size(2BR+1Bath) - 6 radiators + 2 sinks. Have a baby so boiler needs to be reliable and not much hassle with organising call out/service etc., We are on Mains gas., boiler is for central heating plus hot water.
If Baxi Platinum, have you seen any faults with them recently? I was told by Baxi technical team that the Duotec?? is similar to platinum but it has metal components instead of plastic and perhaps more reliable...but it has lesser warranty (7 years).
I want less hassle of course but also the longest guarantee possible. I even read somewhere that there are 15 year guarantee on some products...but dont know where and what the catch is and even what make it is! ;-)
I am also hoping that Baxi Customer services will remain same for the whole guarantee period and they wont fob me off if something breaks 6 years down the line!
thanks,
Are you absolutely sure your existing boiler is past saving? What do you currently have?
Ideal Vogue every time.
Similar to a Vaillant in design but better value. More economical then any of the above. 10 year warranty and it looks pretty.
Bigger isn't always better, especially for combi's. The difference between a 28kw and a 24kw as far as hot water is concerned is about 2 mins longer to run a full (100 litre) bath, assuming you add no cold. The difference is the bigger the boiler the less chance you have of reducing short cycling on heating.
Hot water = approx 30% of your fuel bill
Heating = approx 70%
So the savings are in the heating and the way the system is designed, not how fast you can run a hot tap.
For a few extra quid you could add weather compensation and further increase the efficiency.
I do like the vogue.
Just put a vaillant ecotec in.
Not bad not bad.
But one consideration that must be considered.......warranty !
Historically if your the sort who doesnt get things serviced every year to save a few quid (which loads of people do )
Simply forget about the warranty and get a logic instead.
A large proportion of the cost of the boiler is the manufacturers built in cost to warranty risk.
So naturally they charge more for a 10 year than a 7 year than a 5 year.
Yes the boilers arent like for like.
But my point is skimp on servicing - forget warranty as a deal breaker
It's both if want to be pedantic. They are relative and also the reason most boilers have flow restrictors in them. There is no boiler on the market that can change the rules of physics.
Not being funny, but britony 2T multipoints are 24kW and they were great little water heaters.
Which would mean that in comparison the hot water performance of a new condensing combi would be even better.
Don't the baxi modulate down more than the vogue
I doubt its past saving. I reckon a new PCB or a good Gas engineer can get it up and running for a fraction of the cost which I would seriously consider.
Also, is it normal for an installation company to demand that the old boiler would be their property after the new one is installed. Mine seems to have quoted so and I reckon it is fixable/worth then?
I don't particularly want them to fob me off with installing a new one if they could have their hands on my old one...i dislike this idea!
Please advice..
Please advice..
Officially I believe, any "waste" created by said tradesperson, needs to be disposed of correctly and via a licenced waste carrier. Might you be confusing this with them seeming to want to claim ownership of your old boiler?
I really doubt they'll repair it and sell it on and/or install it. More hassle than it's worth and difficult to test if not connected to anything.
The duo TEC can't get near to vogue on modulation. But it has 7 years on it in terms of reliability
That's true..When you present it like that may be i wont feel fobbed off although still reluctant to let them take the old boiler! Now i know why i need to declutter! ;-)
They're definately not fobbing you off, in fact they're probably more likely doing you a favour by taking a broken heavy old boiler away for you. You don't wanna get lumbered with it, your local dump might not accept it either as it's obviously not waste created by diy lol. Part of the reason you see boilers left out the front of houses for travellers to pick up,or left in peoples back gardens for years
What does the vogue modulate down to?
Baxi goes down to 2.5 kw that's what they are bragging , thought that was pretty decent
Lowest min on the duotec/platinum he A is 7kw and that's on the 24kw (dhw max input net) model.
Im not gonna mention the boiler I think you might be referring to...they all need ripping out
Reply to the thread, titled "New Boiler installation" which is posted in Boiler Advice Forum on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Boiler Advice Forum
Start date
Last reply date
sp25,
dancinplumba,
