Vaillant Boilers, siphon the trap out in one go so I would expect the trap to fill and then empty. Even if it was water from a burst heat exchanger !
I would expect you to find more than a few teaspoonfulls to be honest but I cannot say for certain.
My advice is to get an Engineer to check it for you.
You shouldn't work on a gas appliance unless you're Gas Safe Registered.
Sometimes, changing from open vented to sealed will show up leaks that went unnoticed before the change
Concrete floors , corrosion & expansion issues are the enemies !
(When Hot any slow leaks elsewhere may evaporate .. installer may have some tricks up his sleeve for this )
