the best range 300mts is delta doreSo you can have it anywhere in the house, I assume there's no problem with range?
is that not just qsense stat ?There is a RF version now, only 2 wire connection to the avantas, (take 5v supply from boiler as well as control signal to it through same pair)
asked today and will need the transformer rogerwould be interesting to know if they provide the 5v required down the opentherm connections otherwise would require a transformer to power it (RF version that is)
dirty word, wash your mouth out 😉One last question re boilers. One of our local plumbers has recommended the Vokera range, how do they rate amongst you all?
Vaillant is NOT the BMW of boilers despite what others will say, Any boiler that has rubber pipes inside should be chucked on the scrap heap
Reply to the thread, titled "New Boiler Upgrade" which is posted in Boiler Advice Forum on Plumbers Forums.
