New flue letting water in through middle.
View the thread, titled "New flue letting water in through middle." which is posted in UK Plumbers Forums on UK Plumbers Forums.
Just had a massive downpour and seems the inner tube of the vertical flue lets water in .
The boiler is not connected as the plumber is doing that next week but I have put the flue through the roof hence noticing it .
It's a condensing flue for oil system.
It is new and water is only coming from the middle and no where else.
I didn't know if this is normal .
I wouldn't use a dectite flashing on a flat roof your better off with a spun aluminium flashing there's gonna be alot of water splashing about on a heavy down pour . Kop
Warmflow do their own flat roof flashing available through any of the main plumbers merchants just be careful it meets the manufacturers instructions ? when the boiler is installed , I use CT1 sealant to fix and seal the flashing . Best of luck . Kop
Reply to the thread, titled "New flue letting water in through middle." which is posted in UK Plumbers Forums on Plumbers Forums.
Roosie,
exedon2,
