Sep 19, 2021
Norwich
DIY or Homeowner
Just had a massive downpour and seems the inner tube of the vertical flue lets water in .
The boiler is not connected as the plumber is doing that next week but I have put the flue through the roof hence noticing it .
It's a condensing flue for oil system.
It is new and water is only coming from the middle and no where else.
I didn't know if this is normal .
Flue termination requirements will be found in the manual for the boiler, alternatively in the OFTEC books. They vary depending on certain scenarios.
As Simon says though you really should leave this to the installer. Safe discharge of POC is not to be compromised.
I wouldn't use a dectite flashing on a flat roof your better off with a spun aluminium flashing there's gonna be alot of water splashing about on a heavy down pour . Kop
Reactions: WC1
Warmflow do their own flat roof flashing available through any of the main plumbers merchants just be careful it meets the manufacturers instructions ? when the boiler is installed , I use CT1 sealant to fix and seal the flashing . Best of luck . Kop
