I cant see 17mb inlet causing a massive issue with the ratio. Call out Ideal and get them to sort it.
I know you probably did, but you let it run for a good while before taking reading? I know the Logics run at about 0.0012 from memory, just wondering if it was newness burning off?
Good thinking but I had left it on low for a few hours to circulate with the cleaner and manacleanse
They are coming out today.
Had to leave the boiler disconnected all weekend so my name is mud.
I will update later
I had this with the 1st 40kw vogue I fitted, would do hot water fine but as soon as you put it in max service mode went 0.004 and rose to a max of 0.007, inlet pressure, gas rate were spot on as was co/co2 in min service mode. Called ideal they sent out a guy and changed the injector. The injector opening was slightly oval, nothing major but enough to notice when put up against a replacement. They replaced the injector and it was spot on.
Reactions: 2 people
scott the one i had a problem with was the gas valve was knacked and was pushing to much gas into the boiler, had to order it from honeywell took a week to come in, but they adjusted the gas valve on the boiler to allow safe working
Its not good piece of mind for customers whove saved up money for a new boiler and we have to call engineers out b4 they get chance to use it. Obviously ideal has an inhouse problem as i said in a previous post ive had the ideal guy out on couple new logic plus both with same spark problem . Putting me off of ideal slightly.
