C
Chris Marsh
hi everyone, new member here.
to my nightmare our combi boiler broke down. joy.
our landlord came round with a plumber who disconnected the boiler, installed 3 electric radiators after removing the 3 water rads, re-did some under the sink plumbing to install an electric water heater to feed kitchen and bathroom.
electrics not cutting the cheese, its to expensive.
so i've signed up to ask for some help.
i've found replacement radiators, thats no problem.
the hard part is finding a suitable CHEAP boiler.
it needs to power the 2 hot water taps in the flat and be able to handle the following sized radiators
600x600 single universal radiator
1400x500 single universal radiator
1300x500 single universal radiator (btw if you know where i can buy one this size that delivers please link me to it, only one i cant find)
as far as i know i can hang and plumb these radiators into the pipes (which have been left sticking outta the floor with the valves on still) without contravening any laws as long as a plumber signs off on them.
but i DO know that boilers must be fitted by a qualified plumber and must be condensing?
anyway i need a combi boiler that can handle the hot water taps and those 3 rads.
please help me lol
(p.s i know i also need the landlords permission to have this sort of work done. at the moment im just researching the costs and sourcing parts)
it just wouldnt fire up, well it was trying but kept making a lovely clicking sound.
landlords gas guy has check it, i've looked at it. and we both say same thing (although im not qualified or by any means in the know)
but the pressure cap is effed and almost all the components are suffering sevear rust degradation. the entire boiler does need to be scrapped. i had my own plumber/gas engineer take a look and he said its effed too.
also this was a good 3/4 months ago.
thats how i know electric rads are a rather weak option lol
Any cheap combi will do, how about a baxi duotech or Main combi, dont forget to include flue, time clock, room stat and rad trvs. Btw I wouldnt want be paying to put a new boiler in sombody elses house.
eh my landlord let us off £2400 in rent arrears last year so im happy to pay for it.
problem is im unemployed and cant find a boiler sub £500, nor do i really know what im looking for.
also whats a room stat? i know what a thermostat is, but is a single thermostat different from a room stat and whats a rad TRVS?
sorry i dont know enough about central heating to be familiar with short hand abreviations.
most i know about it is what size radiators i need and how to hand them and screw the pipe connectors on
sub 500 you get a heap, look at potterton performa (a good boiler) or as said duotec but that one will cost a lot more
um can anyone advice on a thermostat for the potterton performa along with a flue?
will anything else need to be brought for it to comply with uk regulations?
i read something about the bedroom needing its own thermostat?
thermostat suggestions also welcome, im preferably after a programmable digital one but happy with a twist dial type thingy lol
combi and rads you are looking around £700-800 for boiler ,flue,timer,and roomstat ! then your looking of around £200-300 for the rad and valves ! and then getting the right person doing it !
i found the potterton performa for £600
the 3 radiators i need come to a little under £150 for all 3. the original valves, pipe work are still in place. so with any luck i can install the new rads directly into the old rads place.
whats this roomstat about?
if bought as a boiler pack comes with a flue,clock separate at £35-£45,regarding a room stat, Honeywell every time if you want it 6to be reliable
£500 will get you an appaling boiler lol!, if you want to go cheaper I think that b and q do one called a vizio or somthing like that at about £478 or somthing like that.Fair play to your landlord for helping you out like that.
A room stat is a temp gauge that goes on the wall and controls the overall heat of the house, a trv is one of those dial controls that goes on the radiator to control the temp of the individual room, a time clock goes on the boiler to conytrol what tim e the boiler goes on and off, all theses controls (or similiar) are needed to comply with part l of the building regs.
so [DLMURL="http://www.discountedheating.co.uk/shop/acatalog/Honeywell_Wired_Digital_Room_Thermostat_DT90E.html"]THIS[/DLMURL] thermostat will do the job with a potterton performa?
thanks for all the help so far guys. knew it was a wise decision to ask for help in sourcing parts and getting advice. im just VERY glad i have no intention of installing a boiler myself (and kind of glad its illegal for me (unqualified) to do it. cant be hacking a 5k fine for it lol
i guess installing it is going to cost alot because of that electric water heating shoved in for hot water taps. something tells me thats completely messed up the flow pattern for the central heating as well.
but then as my understanding goes, the central heating and hot water taps are on seperate loops from the boiler...is that right?
if it is, would it be possible for the installer to isolate the hot water taps from the boiler and just have it running the central heating? or would the under sink heater need to be removed and the plumbing mods there reversed?
stunning thanks for that! its my understanding that the TRV only needs to be on the bedroom radiator right?
ah yes BCG,reminded me about the mare heatline vizo what a pile of poo in the same league as ferroli or ideal
lol okay, well as suggested i will go with the potterton performa. the description of it says choice of 2 built in timers. would either of these be the time clock thats required?
can you link to one please, silly google shopping doesnt return any search results. well turns up some harness looking thing. looks like a parachute harnes actually lol
boiler,clock, or stat what are you looking for a link to?
turd thats gunna push up the price a bit more....guess purchase order will be the TRV's then rads, then room stat, then boiler then the guy to come and do the work. thats going to cost so much....
does anyone have any oppinions of british gas's service where they come in install the new boiler then you pay monthly?
J
J
