C
christmasfairy
Hi, hope this is the right place to ask.........
background.....
We have recently moved into a 1700century house, it has a mains gas boiler (approx 15 years old) it has 2 hot water tanks and header tanks (i am assuming these would be called low pressure?) The pipework in the loft leaked a few weeks after we moved in and the plumber we called said the pipework was in need of replacement- it clearly was, the pipe looked like it had been crushed, it was very thin copper compared to what he showed us is used now.
Anyway- we had planned to replace the ensuite bathroom and a small shower room once we moved in, i didnt expect to need to replace pipework BUT i am happy to do so to hopefully make leaks less likely, we are going to live here for a long long time. The water leak we had was an expansion tank for the heating system we think as the pipe went into a tank- the water was brown and seperate from the cold water tank also in the loft.
My question is- the plumber suggested a high pressure tank system placed in the loft in order to remove the TWO sets of water tanks we have now and therefore remove the cupboards from the upstairs of the house and place ONE system in the loft. If we use the high pressure system and replace pipework from the boiler to the tank and from the tank to the bathrooms would this be a good solution? What are the pitfalls/disadvantages of a high pressure system?
Is there anything else we could do? I figure having two systems is more likely to cause me problems/leaks that one system BUT in a igh pressure system am i right in thinking a leak would be MUCH bigger and worse becasue the water is under pressure?
If we DO go for the high pressure system what would be a good make to go for?
Would it be sensible (having said about weak pipework) to replace all pipework going to the radiators?
Sorry for rambling, i hope my questions are not too dim
Thank you
So a pressurised heating system will be more efficient, less prone to sludge and much much more user friendly - rapid heating and hotter rads.
Unvented hot water system. (Pressurised)
Phenomenal performance every shower will be "5 star hotel standard" fantastic hot water and lots of it. Very low losses unlike conventional system.
But you will need pipework and decent mains pressure and flow
ok, that sounds really good, are there any other considerations? It's going to run three showers eventually. It's a long house so the furthest bathroom with be a fair way from the tanks.
I i like the sound of 5 star hotel showers. At the moment the only shower we currently have is out of action because the grout was leaking in the tiles and I am sick of a bath every night.
Are the unvented systems reliable over a long period of time? Am I going to manage the next 20 years with no dramas?
If you have good water flow and pressure. There isn't a downside.
personally I like santon premier plus. But as long as it's stainless they are mostly the same.
IMHO i don't like megaflo with a bubble top. ( unreliable)
Yes we we have good water pressure, the plumber measured it while he was here.
Originally we were only going to replace the hot water system. I'm going to just go ahead and ask all my questions here because I won't be able to hear the laughing BUT
what are the components of the heating and hot water system??? if we go ahead and have a new unvented hot water system, do we need a seperate tank for the heating then?
Is my old boiler going to be able to cope with that or should we be looking to replace it?
what would be the "dream" set up??
(what a divot, runs for cover)
Plumber said he would make some re enforcements. How much weight are we talking? Are there any other options.? It's timber framed the house and there are some big bum beams up there.
Does it it have to be an over head system? Can the tanks go downstairs?
Get a center store it's £700 for a £1800 tank. Or go all out....
ACV sl coupled to 60kw of twin logics on a low loss
Large investment so:
- Weight, you currently have 2 water tanks, ops with more experience than me could advise but i would not believe 1 pressurised tank will weigh more than 2 tanks
- What do you need? i.e if it is 1 bathroom then why go for a "hotel" system. If it is a 6 bed 5 bathroom then .....
- Get the plumber to quote specifiying the make and model of system recommended & price for job
- Get 2nd plumber to "as above"
- Get 3rd plumber
- Get plumbers to make sure that your current showers & bath taps etc will take the pressure of whatever system they install.
Take 3 quotes, do the forum & google searches and appropriate qualification checks
Go with best option for you, not just best price
You need to be qualified for unvented, make sure the plumber is qualified. Ask for help on here if you need
What is an ACV? is this the brand? if I repeat this line to my plumber will he know what im talking about?
Are there different grades of copper pipe?
Andy- its got 7 bedrooms, ensuite, main bathroom and a shower room,
Currently the en suite has bath, sink, loo, the hot water tank is in the room in a cupboard, id like this moved to the loft to make the room bigger and add a shower and double sink.
shower room standard, shower, loo, sink
main bathroom same as en suite, has a hot water tank and header tank built into the actual room in a cupboard, it takes up so much space, therefore the "want/need" fr this to all go to one system and do away with second tanks, meaning i can then have a seperate shower and double sink in the main bathroom too.
The current bathroom suites are old and fairly ropey, functional but not nicely done. My plan is to get the house right from the inside first, so whilst id love a new bathroom suite all finished i think id be better off replacing the very old and leaky pipework and getting a good tank system in place before ripping the bathrooms out themselves, we simply cannot afford to do everything at once and my motto is to do things once and do them right.
If we install the unvented system and complete new pipework are we likely to blow out all the taps?
Plumber said he would pressurise the system and make sure the old sanitary wear can handle it!?
I hope my questions arent too ridiculous, I must say you are all very helpful, Thank you!! We lived in a new build house before this and never had to get anyone to come and do anything, I find it hard to trust other people and therefore like to try and learn about things at least a little bit before hand. Im not sure how many other 30 year old girls you get lurking on the forums who arent plumbers, but ive already learnt you never ever refill a gas bottle lol
Acv is the rolls Royce of cylinders
A lot of your questions an really only be answered by someone that is looking at the job
If you post your area we can maybe point you in right direction of a good plumber
Reactions: 2 people
ACV as said is the dado. Cylinder comes in yellow y fronts hairy chest smoking a cigar with a lot of 70's bling
Reactions: 4 people
Ok, sorry, yes I will speak to plumber, he is good and came highly recommended but I'm weighing my different options to ensure I don't get a biased system, if you see what I mean.
Chaps........... more help please. I'm in North Essex (halstead/braintree area) I need some recommendations please.
Had our quote back from the plumber, it was a LOT more than I expected......and it wasnt including the ACV stuff!
:bat:
Hi all, im back again,
I need a recommendation of a plumber, the quote has come in and is much much more than i though it would be. ( i didnt expect i to be cheap, its not an easy job) i am in North Essex- halstead/braintree area if any of you know of anybody near here.
His quote didnt include the ACV stuff either, we could have them but he quoted for a worcester boiler and geh tanks.
What would you like your budget to be
