I have 2 other column rads on the 1 pipe system, which are both piped into the bottom of the rad and work fine, so that's what I did with this, I know you can put the feed into the top of the rad, buy can't see it making any difference as it is so poor right now.
The valves are what I have used previous with success, manual angles valves 15mm, which seem to be full bore and not restrictive.
I unpacked etc myself so pretty sure there isn't any bungs etc in there
Thanks for your suggestions, and open to suggestions
there is a big difference between the bore on a normal try and one designed for one pipe as the one pipe one uses gravity to feed the rad not the pump your flow is bypassing the rad.
Thanks I've found the lockshield too, are they suitable for 15mm pipe, or have to change to 22mm ?
[automerge]1606568983[/automerge]
Thanks everyone, thought I'd give you some feedback. I converted it to a 2 pipe system, 22mm feed in and guess what it still didn't work !
So I put in the baffle/ diverter and now works 😀😀😀
Should of put it in to start with but the instructions said not to. Oh well lesson learnt.
About 3 days on it and a few trips to Screwfix haha
