New radiator in loft causing problems
View the thread, titled "New radiator in loft causing problems" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Towel radiator in bathroom has no Trv all other rads have TRV.
So are you staying tighten the white lock shield in the pic?
yes, if this doesn't work then definetly going through rad, is the top of the radiator below the bottom of the f and e tank?
It's not a lockshield valve, I think. It looks like a wheel head Peglers terrier rad valve & as 1King55 has said, maybe a bypass.
I wouldn't turn it off, - get a heating guy to fix everything.
And the difference between a lockshield valve and wheelhead valve are? definetly not a bypass valve.
Same valve, except a lockshield valve has a lockshield head
& a wheel head valve has a wheel head! :smile:
And yes, it definitely is not a proper bypass valve, but possibly used as a permanently bypassing valve & therefore wrong.
I have tightened the valve with the white knob and put heating only on.
This valve sits on top of the tee the plumber has fitted into the cylinder return.
I assume this is similar to the suggestion earlier of a flow from before the 3 port so if this is open as it was surely its a flow?
I was being sarcastic, they are the same thing and so your post no. 52 makes no sense. There is no need for it as 3 port valves close to hot water so always have a circuit, there is no completely shut on 3 port valves. so even if it is a bypass valve it isn't needed!
you want hot water on only to see if rads get hot when hot water only is on, don't you?
Yes just trying that now.
with ch on only all ok but no heat to loft rad. Part of pipe warm where first teed in but doesn't travel to the rad.
cylinder return is now cool since white valve shut. Was red hot all the time before..
on the non return valve on pipework to radiator in loft, there should be an arrow, which way is it facing?
Facing away from the radiator.
With HW only on all rads incl loft rad heat up!
makes me me think there is a problem with 3 port valve but why do all rads heat up except loft rad when ch selected on programmer but all rads incl loft heat up on HW?
is that pipe that you just turned off getting hot?
Not hot no but warm
it used to be too hot to touch but I guess that was when the white valve was open allowing hot water to go straight into the return.
must be the 3 port valve, it may of just been the head that was replaced last time, may have gone wrong again or might just be poor quality.
Whole of 3 port valve was replaced. It is a plumb center own brand about 12 months old. Not sure what they are like? Was done by a plumber.
why would ch only not heat the loft rad but HW heat it? Is this part of the 3 port valve fault?
The cylinder return should always be the last connection to the boiler, or you will get flow down the ch return.
check valve not working or wrong way round, shut rad valves on loft rad, put hot water on only if no rads get hot then its check valve. if all rads still get hot then its 3 port valve. (not sure if you already done this). if it is check valve then maybe it has been manufactured incorrectly.
This may well be the case as the boiler return is 22mm pipe and cylinder is 15mm so it must joint it somewhere.
thanks for your reply.
Thanks again.
I will try this tomorrow but from memory when loft rad shut off all is well. But will confirm tomorrow.
what/where is the check valve?
I think you would be best shutting rad valves in loft for now, if this prevents rads getting hot then as many have said, replace return pipework
You can, believe it or not, have the last tee connection on return anywhere on circuit before the boiler to be for radiators. No flow in rads will occur when hot water on if it is the ONLY tee off for rads return.
Heat can however, rise up the return pipe a bit if the pipe is rising from the tee towards rads, so pipe shouldn't be rising.
Reply to the thread, titled "New radiator in loft causing problems" which is posted in UK Plumbers Forums on Plumbers Forums.
Stevemarch1969,
jase158,
