Post few more photos to the right hand side whet 3 port and cylinder is
It seems simple enough. The plumber has made a stupid mistake, if I am picturing it right.
As you have said, the return to the cylinder is where he went wrong. That shouldn't be joined into for the rad unless you also joined the flow to the hot water flow & at least the rad would work when hot water only on & not effect the other rads.
What is happening at moment when only hot water on, is the flow is going through cylinder coil & then out through the return pipe the plumber has wrongly connected - then through the rad & into the flow he connected to the main rad circuit.
Simple! And it really just is the usual mistake - 2 connections to the main return circuit instead of just one!
that pipe to right of pump, did plumber fit it? the one with white handle on it!!
Think it is below the pump if the picture was right way up. Don't think that should be joined in there, if it is before the 3port. I am confused!
No that's always been there.
he only teed into ch flow and HW cylinder return.
Its a lot easier to connect into the hw return though as that's the only returns in loft, saves breaking walls etc. non return should of solved this though!! The issue is the bypass, bet it was blocked before and he moved it by cutting and soldering new fitting and caused back flow. Need to shut valve and replace with automatic bypass valve!!Kind of says it all! Joining to CH flow & then cylinder return won't work IMO.
Get a heating engineer to repipe the rad.
Either just use the cylinder circuit, so new rad will only work when hot water on sadly,
Or have the new radiators return pipe joined into the returns of the rad circuit somewhere if this is feasible, but NOT into the main circuit!
Towel radiator in bathroom has no Trv all other rads have TRV.
So are you staying tighten the white lock shield in the pic?
yes, if this doesn't work then definetly going through rad, is the top of the radiator below the bottom of the f and e tank?
And the difference between a lockshield valve and wheelhead valve are? definetly not a bypass valve.It's not a lockshield valve, I think. It looks like a wheel head Peglers terrier rad valve & as 1King55 has said, maybe a bypass.
I wouldn't turn it off, - get a heating guy to fix everything.
I have tightened the valve with the white knob and put heating only on.
This valve sits on top of the tee the plumber has fitted into the cylinder return.
I assume this is similar to the suggestion earlier of a flow from before the 3 port so if this is open as it was surely its a flow?
exactly, this is the issue, surprising that you didn't have this problem before though!!I assume this is similar to the suggestion earlier of a flow from before the 3 port so if this is open as it was surely its a flow?
you want hot water on only to see if rads get hot when hot water only is on, don't you?
on the non return valve on pipework to radiator in loft, there should be an arrow, which way is it facing?
Facing away from the radiator.
With HW only on all rads incl loft rad heat up!
makes me me think there is a problem with 3 port valve but why do all rads heat up except loft rad when ch selected on programmer but all rads incl loft heat up on HW?
Reply to the thread, titled "New radiator in loft causing problems" which is posted in UK Plumbers Forums on Plumbers Forums.
