Hi, I have my first service of a WB 35cdi boiler tomorrow and see in the MI's it says to replace all seals with new. Burner and heat exchanger. Is this a must. And do you usually have these in stock on your van? As it says you only need to clean heat exchanger if the fan pressure is less than 5.8mb. Do you clean any way? Also, it says a special tool in needed to clean the heat exchanger, and I have just bought the regin blade. Will this be suitable? And, I am guessing you keep the velcro on the ends of this blade. As not to damage the hex. Sorry, never used a proper tool before. I was shown to use a blunt hacksaw blade.
Cheers fellers
Cheers fellers
