Jan 29, 2016
Hi all. The syphon failed, so I fitted a new Fluidmaster flush valve with side handle which is very good.
I took advantage of pulling the cistern apart to fit a new bottom entry fill valve, namely a Skylo type. The original took forever to fill. I won't bore you with the details but I want a reasonably quick fill. The new fill valve must shut off too quickly as I get severe water hammer now when the valve shuts. I have reduced the main stopcock to reduce flow, and I have partially closed the cistern isolation valve. I now detect a little hammer, but the general house flows are now too low. So I really want to open the stopcock and isolator and attack this hammer another way.
Can somebody please advise what I can do? Can I fit an alternative fill valve that will not cause hammer. It just needs a valve that will shut more slowly.
Incidentally, just after the main stopcock is an inclined pressure reduction vale set to 3 bar, made by Caleffi.
Can I reduce the pressure with this valve and cure the hammer, whilst maintaining a reasonable flow?
Thanks for any help.
Nick
Hello Nick. I wouldn't turn the main stopcock down. All that does is reduce flow everywhere and will not reduce pressure. 3 bar is about what you want. You might be best to have the pressure checked as it is always possible that the PRV and gauge could be faulty.
I would recommend you fit a Fluidmaster Pro valve with brass tail. It should be the type with a red top. It comes with a 'screw' type insert for flow reducer
Defs fit a fluidmaster...
Cheers for the heads up on the viva skylo too, I will stay away lol
Thanks. Will try the Fluidmaster Pro. It says in the specification it is height adjustable 230mm-355mm. Is this the water level? My cistern water line is 195mm.
The fluidmaster pro will fit fine, it's telescopic so can easily be adjusted to fit, a much better fill valve
Many thanks. I can see it's telescopic, but was concerned about the heights 230mm-355mm given. Are these water heights or overall height of the valve? My water line is at 195mm, that is, 35mm below the minimum height given for the valve.
The Fluidmaster Pro valve now resides in my cistern There is absolutely no evidence of water hammer whatsoever, and it fills in a very acceptable time even with the flow restrictor fitted. Many thanks guys for the help and particularly Best who originally recommended this valve. I also have the main stopcock opened to give maximum tap flows, etc, and the cistern isolator fully open again. I will stick with Fluidmaster products in future. The Viva Skylo products cause problems in my opinion.
Reactions: 2 people
