I'm doing a job tomorrow and I need some advice, pretty please 🙂
At the moment the w/m is about 3m away from the spigot on the kitchen sink trap. The w/m isn't emptying properly due to the excessive length so I've been asked to rectify the issue.
My plan is this:
In the pic with the cylinder (pic 1), install a w/m trap beside the red dot and core the wall where the red dot is and run 1.5 inch pipe through that wall. From there it goes into a bunker with gas meters (pic 2) and I've highlighted where I'm going with the pipe on the pic in red so I'll have to core through the wall there too. From there I'll take it outside and run it into a Tee on the 2 inch going into the stack. Obviously I'll fill the gaps in the wall with sand/cement and clip it at intervals as per regs etc etc.
I can't run it internally and attach it to the current waste as there is zero room for it and where the cylinder is there just isn't enough room to get the pipe run through all the copper and other bits in that area. The way I've highlighted seems the only viable option.
My question(s) is/are:
Am I over thinking this?
Is my option viable and to current regs?
I'm a little nervous as I have to core from the outside going into the property and I just need to ensure I don't hit the water pipes *eek*
Could really do with a 2nd opinion..
Cheers all in advance
