Newbie. How can I fit this basin waste to the trap. The trap is only slightly lower than the sink
View the thread, titled "Newbie. How can I fit this basin waste to the trap. The trap is only slightly lower than the sink" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
The Waste is slightly higher than the trap, I've been advised to use the flexi fitting but it leaks and doesn't look strong enough especially as water remains in the pipe. I would call a plumber, but I know its a simple solution.. for someone! I'm a total newbie so advice would be great!
Also the trap is not steady it moves. is there a way to connect it to the wall?
slacken the knurled ring at the top of the bottle (hidden behing the white flexi tube in your photo) and see if you can pull up the riser enough to fit it to the waste. If not, as Shaun says, you can replace the riser with something like this:
Reply to the thread, titled "Newbie. How can I fit this basin waste to the trap. The trap is only slightly lower than the sink" which is posted in DIY Plumbing Advice on Plumbers Forums.
Monti Ali,
Basher,
