J
jimbo21
Hello, Ive just registered recently. Hope someone can give me a bit of advice cheers. Just a quick question regarding the flue on my new boiler. Due to restrictions all around the sides of my house, the only way we could bring the flue out was up through the ceiling using an extension piece then along about 400mm through the floorspace between plasterboard and floorboards straight out of the wall. This gave us the height required above a flat roof.
Then I started thinking, do I need to box the fle in supalux or similair, as its below the floorboards and inbetween joists. Its not tight, a good 3inches either side and 2 inches from the bottom of the floorboards. If its a gassafe requirement then so be it,or if it needs rerouting then so be it. The fitter says its not needed, and all my searching online doesnt seem to cover anything about this. Id just like a bit more advice?
Anyone help?
Anyone help?
