T
tamz
If your house layout suits the pipe runs it may be better to fit a twin coil cylinder, 1500 x 450mm, bigger if you have space, and fit a stove with a boiler.
If you use the stove much (which you probably will) that will effectively give you free hot water. It takes a lot of energy and gas to heat a tank of water. About 11.5kw/hr for 200 litres (90p¿ on lpg) so a saving of £250+ / year.
Things like this is why you should get a pro on board at the design stage where they will be more willing to participate and supervise and test and commission on completion.
Lovely part of the country btw :smile:
