View the thread, titled "Newly installed combi losing pressure" which is posted in UK Plumbers Forums on UK Plumbers Forums.
the last customer that wanted to keep the scrap got to keep the radiators, i was up in the loft cutting out the old primatic cylinder and he's like "don't worry I'll get that" always hovering around like a vulture
explained to him that its part of the job but i was happy for him to keep the rads😛
What flooring was down again? Laminate?
Yep. Laminate in the main building. Our kitchen is on an extension which is around 200mm lower, then we have an extension on the extension which houses the bathroom, and the floor in there is concrete.
It's one of them discussions where you only get to hear one side of the argument. In my opinion its unreasonable to expect original plumber to repair at own cost or for a reduced price. Yes he should have mentioned potential problems in swapping from vented to sealed system. But at the end of the day he has done his job as per estimate, and is the reason why I have a line on my estimates which states I do not gaurantee watertightness of any existing pipework and fittings. Prevents a lot of unpleasantness.
Hopefully you will get sorted without too much mess and disruption.
Its hard to picture your house or how much depth is under the floor, but I would first definatly prove the leak is in the downstairs pipes by getting him back to lock off the boiler and upstairs, if the pressure still drops then its definatly there.
I would pick an area like under a sofa or dining room tabe and make an access hatch to allow someone to get under the floor with a torch.
If you're unlucky then the depth will be too shallow to even get under, if you're very lucky then you could crawl under the whole ground floor.
As soon as the plumber walked through the door and saw the dreaded laminate, any sane person would have mentioned the risk straight away.
These guys get all they deserve, what would he have done if the domestic hot water pipe burst 'somewhere' under the downstairs floor?
My worry is the leak is under that concrete screed floor in the bathroom, probably tiled over aswell with pipes not protected against the corrosive cement.
Or there's a nail or screw through a pipe with a constant drip.
Is there a way of temporarily taking the bathroom system out of the equation and seeing if the pressure loss still occurs? The boiler is located right next to the bathroom. For me, if the leak was happening there this would be a best-case scenario as a new pipe could just be run through the wall rather than having our flooring pulled up.
Not without knowing were the pipework is which is doubtfull considering its concrete as mentioned are all the downstarirs floors concrete?
No, just the bathroom. But thinking about it possibly the kitchen as well... The main building (the bathroom and kitchen are on an extension) is Victorian and somewhat higher than the extension. I'm crossing my fingers that there's enough space here to get under the floorboards.
The plumber could isolate the downstairs pipework then carryout a hydraulic pressure test which will hold a test pressure on the system and any leaks would be seen by a pressure drop on the guage. This would be quicker than just leaving it on the system for a week.
When my heating system was installed it took a few top ups as the system stabilised over few weeks. It is now fine.
Do you have thermostatic radiator valves on all your rads? If you have and they all shut down, and there is no bypass in the system, the boiler can overheat and will dump the pressure out the relief valve.
I am sure he would have checked that though.
Good luck
You can find out if its leaking on the flow or return by shuting off one valve on one side of boiler and all rad valves pressure it up and see if it drops then if not do same for other valve on bottom of boiler.
Good luck
Thanks very much. I will see if anyone in the area will be able to do that for me. Yes we do have TRVs, but considering that one of our rads on the top floor drained empty during the last pressure loss, a leak seems the most likely cause.
It appears the system has been upgraded> The installer cannot be held responsible for underlying issue. I get this situation all the time when systems go from open to closed. I would suggest that you Google water leak detection and get someone to trace the leak. The re-piping is a load crap sounds more like trying to make a bit more work for himself. I would also suggest contacting your house insurance as most will cover this type of service and any resulting damage caused getting to the fault.
It appears the system has been upgraded&gt; The installer cannot be held responsible for underlying issue. I get this situation all the time when systems go from open to closed. I would suggest that you&nbsp;Google&nbsp;water leak detection and get&nbsp;someone&nbsp;to trace the leak. The&nbsp;re-piping&nbsp;is a load crap sounds more like trying to make a bit more work for himself. I would also suggest contacting your house insurance as most will cover this type of service and any resulting damage caused getting to the fault. <br><br><br>
I was reading those 7 pages before this and was wondering why no-one mentioned a pressure test until plumbsy's post. If i'm upgrading from ov to sealed I always describe the dangers and offer to do a test at quote stage for £50, refundable if I get the job.
Good idea, never even considered that previously. I always go with the statement on the estimate about not gauranteeing existing pipework.
Reply to the thread, titled "Newly installed combi losing pressure" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
hedylaura,
E4gas,
