Well cop is 3.3. So a properly designed and maintained system should give out 3.3 kW of heat for ever 1 kW of electricity used according to man data.At a cost.
http://www.nibe.co.uk/nibedocuments/10591/031977-1.pdf
Ideally, you need to know the heat loss in each room. However, the total heat loss in the flat should be enough You can find this out by using .
Information on typical radiators can be found on page 44 of
Post the information.
Flow and Return Temperatures
The flow temperature is the temperature of the heated water leaving the boiler and travelling to the radiators.
Heat is extracted from the water by the radiators, so the water temperature leaving the rads and returning to the boiler is lower. This is the return temperature.
The output of a radiator depends on the temperatures of the water entering and leaving the rad. So this is standardised at 75C flow and 65C return. If different temperatures are used a formula is used to calculate the rad output.
Ideally, you need to know the heat loss in each room. However, the total heat loss in the flat should be enough You can find this out by using Baxi Whole House Boiler Size Calculator.
Information on typical radiators can be found on page 44 of Stelrad Catalogue
It's also important with these systems that the circulating pump is working correctly and the flow rates are not to high
So where are the results of your research?Great - thank you so much for the info and the links.
Some systems do have one pipe connected to the top and the other to the bottom, but this is move prevalent on the continent. In the UK it is normal to have both pipes connected to the bottom.One of my radiators (the largest one) gets hot at the top but stays cold at the bottom? I've been told that is because the water flows through a pipe at the top of the radiator and then flows out of the radiator at the bottom. Does that sound right to you?
If all TRVs closed no heat is being removed from the water by those rads, which leaves one rad to give off any heat. So the water temperature (return) will not drop very far. As soon as tyou open the TRVs the rads give off heat, and the return temperature drops. The boiler then heats the water up.The temperature gauge on the F205 said the temperature was 50 degrees. The TRVs on all of the radiators (one rad doesn't have a TRV) were completely closed at that point and the thermostat was on 14 degrees. I didn't use any hot water, and I opened all of the TRVs. The temperature on the gauge went down to 40 degrees in about 10 minutes. Should that happen?
The temperature did rise eventually. i'm confused; I didn't think the water for the rads came from the hot water cylinder. I thought it was only water for taps that came from the hot water cylinder...Some systems do have one pipe connected to the top and the other to the bottom, but this is move prevalent on the continent. In the UK it is normal to have both pipes connected to the bottom.
However, heat rises, so the top of a rad will always be warmer than the bottom.
Did the temperature stay constant at 40 or did it rise?
The unit has a cylinder, with another hot water cylinder wrapped round it (double-jacket).
If I'm right in remembering, the inner cylinder feeds water for the radiators, the outer one is your domestic hot water store.
Ohhh. So which cylinder does the gauge relate to?
No worries about the private messaging.I guess the gauge on the f205 is domestic hot water.
P.S. I'm sorry about the private messaging. This rotten site only lets you store 1-2 messages at a time.
