No central heating...new boiler
View the thread, titled "No central heating...new boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
I contacted him this morning he's in Wales, have asked another engineer to come on Friday . The only electrical parts the second installer touched is to install a new room thermostat, on original wiring (is this ok), new timer and sort out the spaghetti junction wiring.
In your orginal post you say the 3 way (port) has been replaced and you happen to know the model so it should be that installer that returns to correct it. Another engineer might justifiably say I'm not touching it but having said that Screwfix have a no quible returns policy so you should be able to get a refund or swap for a new unit.
Not sure it was that exact model, I do remember it was a flomaster, ill be abke to confirm exac model number when I get home, if the rain hasn't destroyed the box. Are flomasters notoriously bad?
It's got some very bad reviews on Screwfix site, especially the ones off engineers/plumbers a number of whom have replaced it with Honeywell ones not long after installing. There's a reason they're so much cheaper.
My guess would be wrongly wired from day one and your engineer has just redone what was there. I bet if you pop the head off the new one the fuses stop blowing
He tidied up the wiring in the junction box in the airing cupboard, he said it was a spaghetti junction. Could well still be wrong perhaps?
The fact that he’s “tidied” it doesn’t mean he hasn’t just shoved it all back in, as it was before. I suspect someone (previous homeowner) found that valve was causing electrical issue and removed head
He tried to reconnect it in case it somehow miraculously fell off it was knackered. The previous owners didn't even have the system flushed before fitting new boiler
Again could be poorly wired meaning the motor burned out. Please don’t ignore the fact that there could be a wiring fault
No definitely won't be, ill show the other guy on Friday exactly what has been done, so he can go through his process of elimination
It's permantley in this position?
Does it move easy to the wall (you will have to move the lever) etc when the heating or hot water is on ?
I'll have a go in the morning as the system SHOULD wake up (fingers crossed). I did just turn boiler on and it was doing it's usual...lights on ,making noise ,no hot rads. So we'll see in the morning ‍♂️
So it could be permanntly on. Please just get an experienced heating engineer in to wire it properly
Just had a look in the airing cupboard while I await the engineer I noticed that the wires from the central heating pump and cylinder thermo are touching hot piping...could this potentially be a reason for tripping out? Or just previous shoddy workmanship
Wait for the engineer
Unless they’re bare wires I’d say no chance
Reply to the thread, titled "No central heating...new boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
Leeccc,
Pickwickpick,
