View the thread, titled "No central heating...new boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
The fact that he’s “tidied” it doesn’t mean he hasn’t just shoved it all back in, as it was before. I suspect someone (previous homeowner) found that valve was causing electrical issue and removed head
He tried to reconnect it in case it somehow miraculously fell off it was knackered. The previous owners didn't even have the system flushed before fitting new boiler
Again could be poorly wired meaning the motor burned out. Please don’t ignore the fact that there could be a wiring fault
No definitely won't be, ill show the other guy on Friday exactly what has been done, so he can go through his process of elimination
It's permantley in this position?
Does it move easy to the wall (you will have to move the lever) etc when the heating or hot water is on ?
I'll have a go in the morning as the system SHOULD wake up (fingers crossed). I did just turn boiler on and it was doing it's usual...lights on ,making noise ,no hot rads. So we'll see in the morning ‍♂️
So it could be permanntly on. Please just get an experienced heating engineer in to wire it properly
Just had a look in the airing cupboard while I await the engineer I noticed that the wires from the central heating pump and cylinder thermo are touching hot piping...could this potentially be a reason for tripping out? Or just previous shoddy workmanship
Wait for the engineer
Unless they’re bare wires I’d say no chance
Keep telling People to reed the boiler instructions when job is started first thing it says in instructions is do electric safety checks resistance to earth so on and so forth when you do a full install or a new boiler or change over Anyways first engineer could have checked components on boiler like pump so on and so forth to find if there was a fault in boiler and if a 12 way wireing junction box this made it all the better for me it just shows what type of engineers are out there all to do with guess work this goes on here in Ireland but I taught we were pass all this in UK just shows how wrong I was Hope you get boiler sorted
Reply to the thread, titled "No central heating...new boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
Thread starter
Joined
Thread Information
Title
Prefix
N/A
Forum
Boiler Advice Forum
Start date
Last reply date
Thread Tags
Leeccc,
Pickwickpick,
