Guest viewing is limited
No hot water - boiler not firing - cylinder temp 27 degrees
View the thread, titled "No hot water - boiler not firing - cylinder temp 27 degrees" which is posted in Boiler Advice Forum on UK Plumbers Forums.
No the stat not being cut in to insulation won't be the problem just fitted by a muppet so if they can't get that not right god nows what the problem could be
Sounds more a control problem than a plumbing problem
But impossible to be certain without seeing it IMHO
Reply to the thread, titled "No hot water - boiler not firing - cylinder temp 27 degrees" which is posted in Boiler Advice Forum on Plumbers Forums.
Mark Hunter,
mountainman,
