Got a new boiler recently and was thinking of getting the plumber back to add weather compensation (it's an Ideal Logic Vogue). However, I think I have a problem as the SL for hot water cylinder, which is on floor 2, and the SL for the CH zone for floor 2, are connected together in a mini wiring centre next to the cylinder and thus only one single SL wire is going back to the boiler for the HW and CH zone for that floor. So, I can't distinguish at the boiler whether the call for heat has come from the HW or the CH zone - and I believe I need that detail as the HW should tell the boiler to fire up the temperature output to 80 to heat water.
Can any of you more informed people think of any solution to the problem? Is there any wireless solution that would allow me to pull one of the SL wires from where they are joined so that I'd be able to control the situation by saying having one still use the single wire and the other triggering a controller at the boiler such that I could control what happens there?
Just for info, I'm using Tado as things stand...
