Dannypipe - what was the suction head for the system you mention?
Boiler is aprox 1 meter higher than base of tanks.
Like I say, we inherited the oil supply and cut it just below where it entered the property and split it for the two boilers.
I'm very interested in what you guys are saying as I mainly deal with gas, and find oil installs interesting, even if it is a mucky fuel! I can see bio fuels being popular with some people in the future. So the rules apply there too.
Everything you've said has made sense. I'm just curious as our install was very similar to the original posters and works well.
Boyles law is for gases. For oil, the main factors are Bernouilli's Principle for flow and pressure relationships for change in diameters, the Darcy Weisbach Equation for calculating pressure drop along pipes (which is used to work out pump sizes and pressure settings). Two pipes with the same cross sectional area as a larger pipe will not have the same flow rates due to greater friction because of more pipe wall in contact with the fluid. The shear stresses in the liquid as it flows are annular. The liquid in contact with the pipe wall is stationary whereas the liquid at the centre of the pipe is moving fastest. The gradient of velocity is non linear due to the geometry of the pipe.
These kind of calculations are absolutely critical in larger engineering applications. In sprinkler systems for example, the pipework must be capable of delivering sufficient water at the correct pressure to any part of the system.
No point in me putting much down here - Wikipedia will have plenty of stuff if you want to know more.
yes gases are pretty slow to react but with fluid dynamics the same laws apply but are amplified somewhat
ps whats Wikipedia
Just googled wiki thing interesting stuff even if not all correct
Try Charles law for gases and then look how a gas a fluid or both all react the same time but different depending at what pressure temp and volume gases or fluids are subject.
simple terms cold engine no pressure hot engine positive pressure
liquid volume is smaller because pressure is higher hence so is the temp
it is very similar on an open circuit but not as easy to measure
try standing on top of your missus then your 3 year old it the same physics
thats the good thing about physics they do no change only our understanding of them does
