Hello friends - I really struggle to understand my heating and hot water system
I posted my question on Diynot but it ended up being five pages and couldnt get to the bottom of it and I thought worth asking the elders on here for their view - Hot water temp is 40 Degrees - Ideal Mexico 2 Boiler - https://www.diynot.com/diy/threads/hot-water-temp-is-40-degrees-ideal-mexico-2-boiler.623404/
Questions
1) Is my system fully pumped or not - It appears I have a pump but then rely on gravity to get water back to boiler for heating and also for hot water. I think this is a hybrid and I dont know the terminology - Many engineers who come here are suprised at it and so am I
2) I do not have hot water even if boiler on max demand after cylinder change - Is it because of the pipe bends or cylinder needing to be gravity coil type? Advice from DIYnot has been add a pump after the two port valve but that seems really strange given it worked before orhave a new cylinder made
Help so much appreciated
What I know
1) Ideal mexico 2 bed 125 heat only boiler - There is one flow pipe (3 inch white bore pipe) and two returns (one return from centra heating and one return from hot water cylinder). There is a DAB 65/135 pump on the boiler which pushes the water upwards
2) Cold water and FandE tanks in loft
3) Only one control for hot water cylinder on system
4) Certain I have a one pipe system
Old cylinder is picture below and new cylinder below - Old cylinder did heat up very nicely but new one does not anymore - No changes to pump speed and 2 port valve in manual mode
Old
New
Questions
What I know
Old
New
