Orange spots. Rust. Washing machine or power flush?
View the thread, titled "Orange spots. Rust. Washing machine or power flush?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I get orange spots when washing clothes. Please see photo. I think it is rust.
I’ve checked there’s no metal in the machine. I have also run a long wash with lemon juice. Neither have solved it.
I read power flushing is the answer to rust elsewhere in the system.
How can I tell if it’s the washing machine or if I need to to power flush?
power flushing is for central heating systems.
Likely you have something ferrous in the washing machine somewhere. I would suggest taking the washing machine outside. placing it on a trestle or something and opening the drain hole at the bottom. Try rinsing this out with a hose pipe and dislodge what ever is loose in your machine.
Failing that its probably a new machine
Thanks very much for the reply.
As above, something metal, e.g. a keyring or washer, etc. that's lodged somewhere would be top of my list. Otherwise, have you used anything other than purpose made detergent in the machine?
Lemon juice is acidic, which will cause corrosion. Bleach will cause corrosion, so will salt, etc. Is your water supply from a well? Check the manufacturer's website for advice and do some Googling. Occasionally this type of stain can be due to a manufacturing defect. ISTR that Samsung had to recall some models for this problem relatively recently, for example.
Reply to the thread, titled "Orange spots. Rust. Washing machine or power flush?" which is posted in UK Plumbers Forums on Plumbers Forums.
e5c3d4,
Chuck,
