If you fit a sure stop valve under bath you could possibly fit the switch In a adjacent cupboard
You can buy a tap with a screw out drain in the base, I would either offer that with a disclaimer about draining down, or a surestop switch with a drain in the pipework, I agree with coring the hole through and sleeving it. COMAP WESTCO LIMITED Bib Taps - Bibcock Dzr With Union & Double Check Valve 3/4"
And not compliant with the water regs. DC valve needs to be within the building envelope.
Out of interest Mike, what happens if your replacing an existing outside tap with check valve, is it within regs to replace like for like when no check valve has been plumbed internally?
WRAS Recommendation R15.20"Double check valves have been shown to be susceptible to frost damage and should therefore be protected against freezing by being installed inside a building, or by other means."
I should not steal Mikes thunder but to answer your question Bob, they can be installed as a replacement only, like for like or if the original tap had no protection & it is not practical to install a D/C on the inside (fitted kitchen units etc).Out of interest Mike, what happens if your replacing an existing outside tap with check valve, is it within regs to replace like for like when no check valve has been plumbed internally?
Just to add, you can now buy a 6 metre length of tubing so you could put the switch pretty much anywhere.If you fit a sure stop valve under bath you could possibly fit the switch In a adjacent cupboard
