A
Alex100
I previously posted a thread "New CH system underpowered/ wrong layout?" - and many thanks to everyone who contributed. Issue is now about boiler size.
The installer hasn't once been back to inspect the system since I complained it doesn't heat the house enough, but now he says he just wants to sort this out and put in bigger radiators like I (not he) suggested. He asked me what size ones I want? I suggested he comes and looks in case something else is wrong, especially if it is an oversized boiler, but he just wants to be told what size radiators I want instead (I'm not prepared to take that responsibility).
This installer put a WB Greenstar 38CDi Classic [FONT=arial, sans-serif]combi in two months ago and a whole new system. He put in 9 radiators on two floors with total BTU of about 35,000. However, the boiler does about 38kW or 102,000 BTU. He says he chose the big boiler because I wanted good hot water flow (suggesting it's my fault the boiler that he chose is too big). A heating engineer I met, plus several contributors on this forum, told me that it is essential to have the boiler downrated by the installer to something more appropriate on the heating side (around 10-12kW) - and that it does have the facility to do this without downrating the water heating side.
[/FONT]
We told the installer the boiler keeps cutting out and he said we are getting confused listening to people on plumbing forums, and that the boiler cuts out because the water in the system has reached temperature and everything is okay.[FONT=arial, sans-serif]
Questions:
[/FONT]1. I spoke to Worcester-Bosch today and they said there is no need to downrate the boiler and that it will automatically self modulate down to the 35,000 BTU which is being drawn. Does this sound right to any WB engineers out there?
[FONT=arial, sans-serif]2. [/FONT]Also, downstairs rads "rush" loudly, which makes me think either the pump on default setting 3 is too high (but installer says that's normal combi setting) or else could it be an improperly balanced system causing rushing far from the boiler (which is upstairs and other side of building). Many rads are long long branches from flow & return (up to 8 metres in one case) in 22mm reducing to 15mm - could that cause rushing in rad?
[/FONT]
Questions:
