Mar 21, 2018
Kent
DIY or Homeowner
Hi All
Firstly, it should be known I am not a qualified plumber nor do I have much experience with plumbing, but I am generally ok with DIY.
I moved into a new house and the button press on the toilet was not working properly. Either the button would get stuck down so that the water kept flowing through, or the button got stuck off and the toilet would not flush. Eventually, it the button was pressed so hard, the clip holding the flush bottom in place broke. Therefore, I am in need of a new one. I should have attached some pictures so that you can see what I mean.
What is supposed to happen is you press the button on the cistern lid, so that the flush bottom below button is pressed down, lifting the lever up which is attached to the chain that allow the plug to be lifted from the bottom of the cistern, allowing the water flush through into the toilet pan.
I did try to locate a make/model for the toilet, but the only thing I can see on the whole system is an imprint of MDYA051 on the cistern and I haven't had much luck finding anything through that.
Any help on where I can source a replacement part would be appreciated.
UK Plumbers Forums
Deleted member 120897
C
C
