T
Tone2have
I'm a newbie to the site so go easy on me! The other day we had no hot water. I checked the boiler & the pressure seemed OK. I noted the micro switch on the front of the brass differential assy was stuck open and there is water dripping from the bottom, so I guess the diaphragm needs changing again (done this once already). That bit I can handle.
However I then pressurised the system up to 1.5 bar and turned the boiler off/on, then ran the hot tap. The boiler fired up but I could then hear this whooshing noise and the bar meter shot up past 3 bar? Then there was this loud clanging noise. I quickly turned the boiler off.
I let some pressure back off assuming that I may have overfilled the system and repeated the above, but only to find the same results.
I read it might be the pump has got stock and/or the noise might be "kettling"
any ideas? Thanks in advance
I should copy and paste this like croppie.
Are you Gas Safe Registered? You do know that you aren't supposed to be messing about with boilers if you aren't?
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
[DLMURL="http://www.co-gassafety.co.uk/deaths.html"]CO Gas Safety[/DLMURL]
notice gas safety related advice
