I am contemplating buying a pipe freezing machine, bought a polar freezer kit but in long run think machine would be more cost effective as freeze cans are expensive also not the panic issue of working to a time restraint. On a previous company I used rothenberger plumbfreeze Eco but found it to be a bit unreliable and the clamps are very bulky.
i was wondering if anyone could recommend a good freezing machine that will freeze at least 8mm-28mm pipe? Also what are your opinions on Freezing machines and have you found them useful and worth the money?
The downsides I found with the rothenberger is that it's was a bit unreliable, clamps bulky so limited where I could use it and also took a while to freeze. But did come in useful sometimes and did save draining to replace radiator valves on some occasions.
Would appreciate your opinions
thanks
thanks
