PipeSnug - A innovative idea for plumbers - Finally a quick finish around pipes
View the thread, titled "PipeSnug - A innovative idea for plumbers - Finally a quick finish around pipes" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Quicker, cheaper and cleaner than any other method of sealing a hole where a pipe exits the wall.
No more messy mortar, expanding foam or silicone.
  • Installed in seconds in any weather
  • Safe solution when working at height from a ladder
  • Increases ease of installation by securing pipework prior to fixing
  • Covers brick damage caused by core drilling
  • Prevents water entering and heat escaping buildings
  • Fits all makes of solvent weld waste
Available from CORGI direct - PipeSnug Products - CorgiDirect
I have used these. They are ok. But you are plugging the hole, not sealing it. Also a small bag of sand and cement is about the same price but can be used on more jobs. Do not know how it is cheaper? I would however use them again.
Thanks for the feedback. It does seal the hole, the flexible flanges form an air and water tight seal. Its interesting feedback, do you think it would be cheaper based on the time mortar takes versus 5 secs for a pipesnug ? Pleased you would use again. Feedback very welcome. Thanks
I just got a couple for free due to orders and found them great too though. I guess it is easier to get hold of the sand / cement stuff than the snugs. I would not drive 6 miles just for a pipe snug. In my opinion these are looking a lot better and neater than sand and cement but as @Harvest Fields has mentioned is it really cheaper surely not when you have to drive for them that far. It is definitely a good solution for heights and quick to install.
Perhaps I have to get a couple to van stock them
1 x bag of sand and cement pre mix £5.00 and will do about 30 11/2” condense holes. 1 x pipesnig £5.00 each x 30 = £150.00? In my own personal opinion of course.
Reply to the thread, titled "PipeSnug - A innovative idea for plumbers - Finally a quick finish around pipes" which is posted in UK Plumbers Forums on Plumbers Forums.
CorgiDirect,
CorgiDirect,
