Pipework for downstairs radiators on new builds
View the thread, titled "Pipework for downstairs radiators on new builds" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Hi on some new new build houses I plan to first fix the up stairs radiators in 15mm copper coming up though the floor at the pipe centers for the radiator. i,e rad. length add 45mm per side and the correct distance from the finish wall. However I am debating how to feed the downstairs radiators, this pipe work is usual feed behind the dot and dab plaster. What do people find is the best way of doing this. Thanks for any advice.
22mm copper primarys to 2 zone valves then manifolds. x2 return manifolds 10mm plastic pairs to each rad with foil insulation tape behind drops and pipes centers of rads 100mm above base of rad. V plates after drylining pushfit chrome m&f elbows into valves.
Thanks for the advice may drop in 10mm plastic and use a back box. Is it then usual to use back boxes for the upstairs radiators?
back box wtf do it right
and you can do upstairs the same or have them coming straight up into the valve (copper)
Yes thanks for the advice. Do the rad valves above work with polyplumb pipe and liners, or do you need a liner specific to the valve?
no if 10mm valve (not the reducer type) they should but never used poly as most of the time im ripping the stuff out but as with any plastic pipe use an insert/liner
Reply to the thread, titled "Pipework for downstairs radiators on new builds" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Mgrant,
lame plumber,
