Plastic or copper? which is best?
View the thread, titled "Plastic or copper? which is best?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Copper but starting to use a bit more mlcp these days
Easier to snake around the sparkys
Out of curiosity, is that pipe suitable for standard hep/JG push fit fittings? It could be quite easy to mistake it for standard pushfit if you only took a small section of board up and only saw the pipe, not the fittings.
hate barrier pipe {jg/hep/polypipe etc etc} with an absolute passion! , the only pushfit system that i like is pegler yorkshire's tectite, its a MLCP pipe so it can be bent by hand and stays in that position and doesnt expand anywhere near as much in length as plastic does , comes in 15/22 and uses double sealed liners with stainless 316 fittings..
Buteline offer a 25 year warranty on the plastic pipework. It has no O-rings and is press fitted.
Their rep said they will be upping this to 50 years soon.
Gerberit offer a 1 year guarantee on their Mapress copper press fittings.
How long a guarantee do you offer on your hand soldered copper pipes?
If you want to offer a manufacturers backed warranty on your installation, like you do with boilers, the answer seems simple.
Install plastic
[lights fuse and retreats to a safe distance]
Install plastic
25 years geberit offer
I’m DIY of 40 yrs experience. I recently did a re plumb job for daughter. By pass leaking underfloor pipe (2 litres a minute). The job took far more time than myself and brother-in-law estimated. Like 6 times as long. Very awkward access, under bedroom floors and in tiny loft etc. Waving a blow torch in restricted space not easy or quick. Had it been easy to get at we could have done it in a fraction of the time. Plastic would have made it much easier ... long pipe runs, gentle curves over rafters.
My costing for MATERIALS, Screwfix prices. Copper and plastic pipe .. not much in it. Copper and plastic joints ... copper wins Easily. Fitting. Plastic is so quick, less joints. Now I prefer copper but I had to use one plastic bend in an inaccessible place on copper pipe. Amazingly easy. See photo at bottom.
My experience of copper is that is sometimes doesn’t last as long as you anticipate. I had two pin hole leaks in 30 years in copper cold water feed to trad boiler, cast iron boiler , not combi, feed was from expansion tank in loft and flow down pipe must have been virtually non existent ... just water expansion. But might have been bad pipe?
So I would say a proper job with longest life would be copper. fittings look better. I suspect quotes for a plastic system would be cheaper as there must be less labour. In new house builds what do they use? In top end house builds what would be specified, reguardless of cost?
At the end is photo op plastic fitting I added in inaccessible place to join 2 copper pipes. I had to cut away wood to give space to fit it. I haven’t forgot to insert the other pipe! Oh yes. Some plumbers don’t clean flux off copper ... and it corrodes. I believe British Gas had problems with corroding copper pipes and did a lot of research on what fluxes not to use.
Then was a plumber friend who had copper oil line, passing thru wall, corroded through in weeks. He had no idea why.
So Copper can give a Proper job, more expensive, can be longer lasting, rodent proof. Visually less intrusive and you can see some beautiful curves from skilled pipe benders. Polishes up nicely ... I once worked as a loo attendant after leaving school, and during Uni hols. Polished the copper urinal pipes every day.
Plastic job, likely to cost less as less labour intensive and less skill needed.
Reply to the thread, titled "Plastic or copper? which is best?" which is posted in UK Plumbers Forums on Plumbers Forums.
Rob876,
Welder,
