please help its my boiler im desperate
View the thread, titled "please help its my boiler im desperate" which is posted in Boiler Advice Forum on UK Plumbers Forums.
L
legzi
hi this morning i turned up the pressure on my baxi boiler to 2bar but when my girlfriend later turned on the boiler it ****ed out water
at the moment it has stopped spurting water and when i turn power on the lights come on like its working and it makes a few noises
the flame does not light and the pressure is at zero
is my boiler nackered or can i save it please help anyhelp is appreciated
youve probably overpressurised it, and the tpr valve has popped open. shouldnt be a problem, call a plumber tho, you need to understand a bit of the basics before you touch it yourself, so best left alone.
shaun
shaun
i just sent u a pm coz i wasnt sure if u would knew i replied sorry am new
hi mate it has over pressured definetly then its spurted out the prv like u said the electrics seem to be ok as it all turns on the flame doesnt come on though and the pressure is at zero sum1 said the flame wont light if theres no pressure is that true isnt there any like standered procedure for this kind of thing coz it must happen a lot i have a bit of knowledge i just need some guidence please help me mate what would you do if u was called out for this kind of job what things would u check and that sort of stuff
i cant really afford a plumber and im in the **** with my girlfriend please help
I am given to understand that British Gas allow one to take out a monthly paid yearly
insurance so you could probably get it fixed for not very much money...
yes they do but if you start the monthly plan 20 ponud a month u have to wait 30 days before they can fix it or u can pay around 150 and they do it within a week u still gotta sighn up for a year though
Therefore although the problem with your boiler sounds simple,
Because of the power of the HSE over all of our lives it would be unwise for a plumber to suggest a fix to someone who`s expertise lies in other areas.
i have an idea am just not sure if it will make it worse so i cant afford to try it i think i need to reset the boiler then put more pressure into the boiler but am not sure if its a simple as that could anything happen if i try that
just took the front case off the boiler flame still wont ignite but is clicking
when i attemt to repressurise the boiler water spurts out thetop of the condensate trap help me plz
Hmm!
Although you should not touch it unless you are competent to do so and the boiler is yours, or your GaSafe registered.
One of the causes may be beside overpressure is that the condensate line is blocked.
This causes a lot of problems similar to the one you mention. Its a safety feature that keeps the boiler off if there is no way to drain the condensate water. And if your condensate water is spurting back at you, it may indicate a blocked condensate line.
Hmm!
that sound like the problem the water comes out of a 2 to 3mil hole at the top how would i unblock it or what do i have to do to fix it
and dont worry the boiler is mine on my own property so if i dont fix it i will be robbed by brittish gas thanks for taking your time to reply
Reply to the thread, titled "please help its my boiler im desperate" which is posted in Boiler Advice Forum on Plumbers Forums.
legzi,
legzi,
